Originally Posted by brillo_76
So you are thinking the 2 Glove Box connections II2 and II3 have something different from 1997 to 1998?
I always thought those were just engine harness disconnects. As with the other plugs for the engine harness that go directly to the ECU..
I see in the morning here on my parts rig to see if these wires change colors when they go through that glove box connector.
As I have the dash 95% out its easy to look at those plugs and verify.
I never looked that closely at those connectors so we shall see. :-)
in this case because they are the 97 from engine harness the plugs are Version 1997. the connections are version 1998.
physically comparing the V97 vs V98 and connector type
1997 II1 dark grey -> 1998 II1 dark grey
Pin 1 black/white->Pin 1 black/red *mismatch color
Pin 2 violet->Pin 2 violet
Pin 3 yellow/green->Pin 3 empty *mismatch
pin 4 light green->pin 4 light green
pin 5 black/yellow->pin 5 black/yellow
pin 6 black->pin 6 black/white *mismatch color
pin 7 black/blue->pin 7 black/blue
pin 8 red/blue->pin 8 red/blue
pin 9 red/yellow->pin 9 red/yellow
pin 10 empty->pin 10 white/red *mismatch color
1997 II3 White ->1998 II3 White
Pin 1 violet/red->Pin 1 violet/red
Pin 2 light green->light green
Pin 3 black/red->black *mismatch color
Pin 4 blue/yellow->blue/yellow
Pin 5 white/red->yellow *mismatch color
Pin 6 red/green->red/green
Pin 7 white/black->white/black
Pin 8 green/black->green/black
Pin 9 black/red->black/red
Pin 10 blue/red->blue/red
Pin 11 empty ->green/red *mismatch
Pin 12 pink/black -> rest down match fine
Pin 13 black/yellow
Pin 14 red/yellow
Pin 15 brown/red
Pin 16 green/red
Pin 17 white/blue
Pin 18 black
Pin 19 pink/blue
Pin 20 white/blue
Pin 21 green/yellow
Pin 22 green/black
Pin 23 brown
Pin 24 yellow black
Pin 25 green white
Pin 26 yellow red
so just the mismatch is
