Window lock stuck after battery change...please read.
Hey there guys. Before you leap to conclusions and send me links to resetting automatic window close settings or 'normalizing' the windows after a battery change, please read the post first. Thanks. I've searched the forum for my specific issues but haven't found a solution.
So, changed the starting battery in my 2017 TRD Off Road. Lost automatic window opening/closing on the rear gate window, driver's side window and sunroof. All reset now and working well.
What is NOT working is that I now cannot operate any windows other than the driver's side front window from the driver's door controls. However, each window is working if you try to open it from the switch on it's door. So, if I want to open the passenger front window, I can do so from the front passenger door, but not from the driver's door control. Effectively, I cannot open any window other than front driver's side window from the front driver's side controls.
Any suggestions? Could this be a fuse?
Thanks in advance!
b
e
n
2017 TRD Off Road
