Originally Posted by St Runner
Sounds like lower control arm bushings. Its hard to check them with the coilovers attached as there is always pressure on the bushings. Either look up how to check them with a pry bar or remove the front suspension. You won't be able to check with just your hands. Better to do this before an alignment or as been advised, bring it to a shop that knows what they are doing
I was prying on the control arms with a pry bar but it was on the ground. I haven't been able to find anything on how to check these bushings in particular but I've seen some things on general suspension bushing checks. I should probably do it with the car on stands though.
Been having some trouble finding an alignment shop I'd trust. Yelp is a confusing place.
