Originally Posted by graysquirrel
Is the shocks and struts that Toyota uses different for the TRD Off-Road than the SR5?
Got a limited and wondering what it would take to put that suspension on mine.
Would it be just the shocks all around, would I need the springs too, and what else?
Todd
Same shocks on the Offroad and SR5. The Pro model uses a different set from Fox (previously used Bilsteins).
Regarding putting any aftermarket shock on the limited, you'll have to disable/remove the XREAS system when you do. If you want to replace the shocks, I highly recommend looking elsewhere instead of OEM. Like Bilstein 5100s are a good all around value shock.
