Originally Posted by ProfessorP
Thanks for the link! I am going to find something comparable to try out. I like having options. Appreciate it!
Originally Posted by maca1
Sorry for the thread drift
Thanks for making this thread about you. May your rack rub! lol jk. Good luck with it.
Originally Posted by jp.vegas
Yes exactly those. They loop around the bar, you hook the end of the ratchet strap into one and then do the same thing on the other side. Takes the guesswork out of using the pro rack and is the proper way to tie the strap to a round member that the hook won't fit on.
Thanks for confirming! This seems like what will work best for me. What straps do you use, if I may ask?
Originally Posted by Jetboy
As a general rule - I almost always use typical 2" heavy duty ratchet straps. Most 1" width straps are garbage. I'm sure there are some good ones, but most are crap. The ratchet mechanisms are usually just not very good and dont' last a long time.
Incredibly helpful post! Thanks for that. I admit, I was going to do the no-no and wrap around the object prior to around the rack. Thanks again for all the tips. 2" it is, with the proper ends. Awesome. Thank you!
