Originally Posted by franky73
I managed to pick up a 1996 elocker to swap into my 2002. Unfortunately the unit came with no axle shafts. I am hoping to use mine from the 2002 as I was planning to do my rear seals and bearing at the same time.
I have searched and searched but seeing as there are different part numbers of the bearing can anyone confirm my 2002 shafts would work? I am also assuming seeing as the axle is 1996 I should be using the older style bearing part number?
Any guidance would be greatly appreciated. Going to have to get on this quick as with temps dropping my rear seal leak has really kicked up.
2002 axle shafts will work with a 1996 housing. Axle shafts changed mid 2000 so when you go to do the axle bearing it will need to be for the 2002 axles. Rear axle seals, snap rings, retainers, and abs tone wheel are all the same. I would recommend replacing the inner axle seals and inner axle retainers.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
