Originally Posted by NW.OH.T4R
Unless you're purchasing a Pro, this lift will not work for you. The Eibach Pro Truck lift would be viable. If you are going full steel bumpers and towing a small trailer regularly, I think Dobinsons may be a better route to dial in a spring setup to fit your needs.
There is some really good information on this forum that discusses gear ratios and increased tire size. Good luck on your search!
Thanks for the response. I’ll keep searching. Not getting a Pro. I really don’t want to have regear from the get go. Too many other mods to do. Likely one of the lighter weight front bumpers just for a winch but the back will eventually have a dual swing out. Trailer tongue weight is around 300 lbs. I could do air bags to accommodate for that instead of heavier springs.
In my head I am thinking get an adjustable setup with better factory sized tires. 50,000 miles down the road or so I can then consider 33” tires, regear, etc.
FJ took nearly 8 years to build up and this one will probably be 8 months to a year foe most things. Lots of $$$$ out the door in a short period of time.
