Originally Posted by kc15842
Did you have corrosion on the heads? I've had a couple 22R, and the first head gasket replacement I also had to weld the water passages because they had corroded to the point they were larger and would evidently grow past the seal area. I now replace my coolant more often.
neither the head nor the block had any notable corrosion of the coolant passages.
