Thread: 2006-2009 drl
View Single Post
Old 10-21-2020, 11:31 AM
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Depends on the MFG and type. What I would consider as the DRL are actually the front signal lamps. That is, if you are referring to the amber side markers up front that are on regardless of headlight setting.
Basically a 1156 Amber (twist lock base) for standard options.
Here are some LED options from box stores:
https://www.napaonline.com/en/p/NDP7...put=light+bulb
https://www.autozone.com/electrical-...1_0_37365_2805
The smaller markers below which are technically the DRL according to the manual use a 168 wedge base bulb. LED options would be something with a T10 base. Both readily available at your local auto stores.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
