Ok I "think" I have this figured out after more reading of
SSt4r
thread. My skid control ECU is under the dash on my 03. I think all I have to do is cut the red/white wire at pin 26 and tap it into the red/blue wire at pin 3 as illustrated by
SSt4r
pic below. For my 03, TIS shows different pin numbers.
Then order either 84988-AE010 (trac off) or 84988-35070 (squiggly lines) switches, modify the switch and just plug it in. Will either switch work with the blue harness? I'm guessing it just depends on what you want the switch to say?
Does this seem correct?
