Originally Posted by toyotaspeed90
Old drivetrain gone....
Now I'm a bit shocked by what I see.
It isn't uncommon to have varying parts or wiring between trim levels...
Buy the body is literally stamped different between an SR5 and a limited.
The limited has a very different opening at the center console than the SR5.... the floor plans are literally stamped different instead of having a variation of something that simply bolts (or even rivets) in place.
Guess I'll be cutting it here soon...
For the shifter cutout in the transmission tunnel, try to keep the bolts as untouched as possible. I can take a picture of what I did, but I managed to bolt the manual trans boots (TBF mine were from a tacoma) onto the 2 bolts that were 1 row down from the very top. Then I cut up the auto shifter metal and welded it to the bottom of the shifter boots so I could use the bottommost 2 bolts to get a good seal. Wasn't very hard, but make sure to hold your breath while welding, the shifter boot metal bracket is galvanized.
