I don't think its the shift solenoids. I don't believe the transmission uses the solenoids for reverse gear, it's purely mechanical through the shifter linkage.
If I had to guess, it probably has a plugged up filter which is starving the pump or there is something plugged up in the valve body. The pan would need to be dropped and the filter replaced (likely it is plugged up). The solenoids could also be tested if the pan was dropped just to make sure they are in spec.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
