Just a thought or possibility, Since the rims where suppose to fit, maybe you have the Tundra brakes already, think the castings are 13WL 13WE s13WE and 13WG for the Tundra? And s13WM for 16" rim 4R's. How long have you owned the truck, maybe the PO did the upgrade, what is the casting number on the caliper out of curiosity.
Edited for other castings
