Originally Posted by Bad Luck
Did you check the primary and secondary sides of the ignition coils? What were your resistance values? I had a similar problem that ended up being a bad ignition coil that resistance tested within specifications.
I'm going to agree with this. Cylinders 1 and 4 share an ignition coil, so my guess is that's going to be your problem.
