Originally Posted by Lolaya
So I definitely have a leak and it must be fairly big if it takes 2 weeks to drain it.
Where does the fluid go from the bottom of the reservoir?
Does it stumble/misfire at startup?.
Any error codes?
If none, you could try swapping the radiator cover to a new one.
Or have a shop perform a compression test on the cylinders or a leak test on the radiator.
A cars cooling system has many point for potential leakage, you need to patiently go through them
2005 v6, galactic grey 4wd auto :
pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......
sold
2004 rav4 titanuim silver 4wd auto :
pionneer avhx 5500bt hu, pyle reverse cam
