And I wouldn't rule out rear wheel bearings, mine are making some weird sounds that changed over time, took me awhile to figure it out as the sound resonates through the vehicle, had it rolling on jack stands and my diff was noisy, pulled the rear axles and diff, and as closely as I checked them on the vehicle, until the axles where removed it was obvious the original bearings at 300,000km where due, this noise has gotten progressively worse and changing over a year, a rumbly grumbly vib noise that can be felt in the t-case shifter as a vib.
