Originally Posted by klavender1
Here is the skid control ECU. It is under the dash in-between the parking brake and brake pedal. At least on our cars (2003 & 2004 V8s). The red arrow points to the plug you'll need to unplug and work with.
That's it! Once you plug in the modified TRAC switch, it works as intended. The switch lights up at night, pushing it anytime causes the "VSC OFF" light to come on.
You're the man! Thank you for the detail and insight. I spent WAY too long modifying my switch to the on/off mode instead of momentary. I ended up sorta getting guitar string to work, but it feels super fragile and may get stuck in the on position... in any case, I'm gonna grab some wire taps from ACE today and see if I can tap the two wires together.
