Originally Posted by klavender1
That's it! Once you plug in the modified TRAC switch, it works as intended. The switch lights up at night, pushing it anytime causes the "VSC OFF" light to come on.
It's done! My '04 has the same procedure as yours. I spliced the red/white into the red/blue. I modified my switch to finally work consistently. I actually took apart the DAC button to get the exact dims and wire thicknesses I needed to get it to work. I ended up using guitar string (high E and a G string) to match the components of the DAC switch.
When I hit the button, the CDL light comes on, but no engagement of the locker, and the VSC Off light comes on as well. Everything seems to work as intended!
Thanks so much for the help
klavender1
