Originally Posted by anomalous
Interesting thread. I never thought of upgrading bump stops, but it makes a lot of sense. I went with Energy Suspension bump stops for the front, and Durobump 3.5inch bump stops for the rear. I'm on a 2F\1R inch lift. The Energy bump stops are about an inch to an inch and a half taller than the stock front stops. Do they actually compress enough to not limit up travel? Thanks!
Just noticed a mistake on SDHQ website where I ordered the Durobump "1.5inch" rear bump stops from. 1.5inch would actually be shorter than the stock bump stops, so wouldn't work. The part number for the listed "Durobump stop 1.5inch" rear bump stops is DBR35. It must actually be 3.5inch tall, not 1.5inch that is described. Makes sense since the 4.25inch tall ones have part number DBR425, and meant for 2+ inch rear lifts.
Hopefully avo1789 can confirm this
I got the energy bump stops at the front too, I will be off-roading this weekend so I will test them out properly and try to bottom them out.
Anyway, even if taller, they are much softer (I can compress them with my hand a bit) compare to stock. I am pretty confident they won't limit travel at all, especially if lifted.
