Can you please take down or edit the post where you incorrectly remove the CV axle with a home-depot woodworking prybar and a hammer and damage the differential housing and seals?
This is the tool that should be used every time:
Amazon.com: OEM TOOLS 27305 Axle Popper Kit, Fork & Shim Tool, Remove Most Vehicles’ Half-Shaft Drive Axles, Fix Damaged CV Joints: Automotive
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
