Originally Posted by wcjeep
Was the Viper system installed correctly from the initial install? Probably not. Something has probably been wired wrong for sometime. Was the Viper system installed with wire half taps? Half taps can induce problems like dirty opens (partially connected).
Removed all of the half taps and checked wiring. Finally got the engine to run on enough cylinders to throw codes P0340 and P1300. Checked Cam sensor ohm again and pulled on ignitor wiring to see if anything was loose. I will check wiring between ignitor and ecm, think I saw a test procedure somewhere online.
