Originally Posted by timbren-industries
Our bump stops are designed to hit square and reduce the impact of the bump. Let us know if you have any other questions!
Thanks for the response! Forgive me if this seems like a silly question, so is there a good average distance you should have from the bottom of the stop to the top of the dif? I mean, there must be an optimal distance. It seems that too much or too little distance and you don't get the full "active" benefit, right? Understanding of course that there other factors involved but most of this generation truck lifts range from 0-3" so using those as baseline is pretty acceptable IMO, only outliers are lifting in the +4" range.
Like this FJ has what looks like a 2" spacer, of course we have no idea what lift they are running apart from the fact they stuffed 37's on it (outlier
Login • Instagram
2013 TE w/ KDSS Nav
=-> Get yer
Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just
want to go "Pro"
