I did both front bearings and pressing them in and out wasnt too bad. One caution is to make sure you leave the plastic holder in while you press it. Otherwise the cone bearings will fall out. Get dirt in the bearing and you are screwed. The oem hubs are better than any aftermarket unit. I would buy the bearing and press it yourself.
Here is the dirty little secret of the bearing industry. Each manufacture doesnt make every bearing. For example I bought a SKF rear wheel bearing from Rockauto and when I got it, there was a koyo bearing in the box. So koyo supplies that bearing for SKF. As mentioned above, avoid Chinese parts.
This BeckArnley 0516444 front bearing on rockauto looks like its a KOYO bearing with seals.
More Information for BECK/ARNLEY 0516444
You will need the outer seal which goes on the bearing before you press in the hub. And dont forget to put the bolts in the bearing before pressing the hub in. You cant do it later.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family-->
I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
