Originally Posted by llopness
What's required to put an electric brake booster from an 01-02 3rd gen into an earlier third gen?
Swapping the body, frame, all electronics...
Well, kinda. The brake booster is also the ABS and traction control system in the 01/02's. ABS was changed from 3-channel to 4-channel, so almost all of the brake lines are different, it uses a completely different ABS computer, integrated differently into the dash harness. Heck, it is even (partially) integrated into the engine control system with the sort-of drive-by-wire system for the throttle.
Use a vacuum pump. The diesel motor should already have one - either electric or mechanical.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
