Originally Posted by nglayton
With the arclight map lights and rear hatch upgrades you can pull the whole unit and make the install in the bench and simply snap the fixtures back in place.
The hard part is with the dome light, it doesn't come out or disconnect the way the other lights do. It's practically hardwired in with no disconnect so you have to install it in place on the ceiling. Makes it hard to reach and you get tired holding it up to make all the changes.
So remove a couple screws and pull the whole overhead console down and work on it at a bench. I put mine together at the kitchen table. This is like the people trying to use tape to remove the front dome light bouu look at instead of taking 1-2 minutes to drop the housing and remove the bulb sockets from above as intended.
