Originally Posted by Mutant138
Nice. Solid idead.
Also a word of advice you don't want any of those special drain valves if you offroad. One good smack of the skid and you can end up puncturing your oil pan with the valve. Stick to a normal drain bolt as it gives you the most clearance to the skid.
Huh, I hadn't thought of that scenario. It's worth considering.
Anyway, I originally bought the Valvomax as I like the design. The OP is correct in that the access hole in my RCI skids isn't large enough to install and operate. I have the Fumoto, and for what it's worth, I have no problem reaching in to operate the valve.
