Originally Posted by thezentree
Squeal - YouTube
Not sure how to embed or I would...
Definitely seems to be coming from the hub or brake, and I did wheel bearings about 1000 miles ago. Only present at ~5mph or below.
Did I screw up installing one of the seals? Wheel bearing? The wheel and spacer are ambient temp after 20 minutes of driving, so I don’t think the bearing is bad.
I hosed the brakes out with the hose and then a bunch of brake cleaner, so I don’t think there’s some crap stuck in there, but who knows.
It sounds like a squeaky or dry seal to me. Are you confident it's coming from the hub area and not the differential? Does it continue to happen if you keep the wheel spinning in the same direction?
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
