Originally Posted by derekwilliams345
I traced the wires around the best i could and even took apart the Body ECU and cleaned up a little corrosion inside.
This jumped out at me... There should be absolutely zero corrosion inside the body ECU. Was the corrosion next to the electrolytic capacitors (little vinyl sleeved can looking things)? If so, your body ECU needs to be repaired (caps replaced) or replaced.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
