Originally Posted by 96RedRunner
Yea that did come off Monday morning over first coffee gruff, my bad, ha. I''m with you on Audi lights in Runner.
Grounding battery vs body my opinion. For the amp load a body ground will suffice proper wire sized,
this particular load (headlights) I'd go to battery, for the least resistence to ground path.
The less expensive harness can be upgraded to battery ground for way less than than what your paying for the other.
3' piece of wire, solder, terminal for batt, heat shrink all you need.
Picked up the wire, solder, heat shrink, and a set of helping hands tonight. Now I just need to locate a good soldering iron. Haven't soldered anything in about 20 years. Looking forward to it.
Sent from my moto x4 using Tapatalk
