Originally Posted by DMV4runner
Couple of things to try.
1. Keep spraying with the PB.
2. Get a ball pin hammer and a regular hammer. Put ball against bolt and tap flat side with other hammer. Hopefully the vibrations created will allow the PB to penetrate deeper.
3. Try to tighten the bolt. It might break the seal allowing you to loosen it.
Good luck.
This except if you can get some Aero Kroil use that instead of PB Blaster. Plan B is grinder wheel to cut it off.
