Originally Posted by leepoffaith
I recently did the TBU with the Powerstop kit from Amazon and I have the soft pedal too!! It stops just fine, but the brake pedal engages slower and lower then it should. I have bled the brakes at least 6 times and still have that feeling. If I press down a little then lift and then repress the pedal it is perfect. I even tried going down a gravel road and engaging the ABS system to get air out TWICE and that didn't do it. I finally gave up and I'm sitting in the waiting area of a Toyota Service Department right now waiting for them to do a brake system bleed with their computer in order to actuate the ABS system and hopefully get the air out. The tech test drove it and felt exactly what I felt and said it definitely should not feel that way. He thinks it's an air bubble somewhere. We shall see!
What did you learn? What did you have to do to fix the problem?
2000 4Runner Limited, 2" ToyTec Body Lift, 255/85R16 Maxxis Big Horns, 3" Lift Bilstein 5100s front and rear, OME 891 rear springs, 4x Innovations Rock Sliders, Silencer MOD, Deckplate MOD, PlastiDip Guru, Total Chaos UCAs, ToyTec Adjustable Rear Lower Links and Panhard, Tundra Brake Upgrade
My Build Thread
