I recently got the valve cover replaced to try and fix an oil leak that had developed. The thought was that the shop could tell that it was leaking from there, but not sure if additional leaks from other areas so just did that a couple months ago. There is still a leak and seems to be getting progressively worse with larger spots developing where I park after driving. Here is a picture from where the oil drips from. There is oil on everything under the car as high as the starter. The shop suggested I bring it back in. Any thoughts on what else could be leaking? This is a 2002 with 154k on the clock.
