All aftermarket and "upgraded" PS pumps ALL come with a reservoir, since he has done 3 pumps I would assume, so we'll see if this makes an ass outta u or me. OP?
*and the chances a garage is going to use OEM parts are slim to none unless it's a dealer or specifically demanded.
