View Single Post
Old 12-09-2020, 08:04 PM
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by WRTR5 View Post
Ok so I'm probably being a baby but this screech on cold start is concerning me. I'm guessing it has something to do with the power steering pump?
2005 4Runner Screech on Cold Start - YouTube
Originally Posted by royal T4R View Post
V6 or V8
It sounds like an electric pump, not mechanical. My V8 also makes a noise similar to that just not as violent. I believe it has something to do with the brake booster.
I also think it's most likely the electric ABS/booster pump motor making the noise, if it is the motor it should also make the noise when you use the brakes several times, normal operation is the motor comes on when you turn on the ignition and also comes on after you depress the brake pedal approximately 3 to 4 times as the pressure drops, the motor normally runs about 10 to 15 seconds or so the motor should only make a slight buzzing noise but if the brushes are worn down it will be much more noisier like the noise you're is making.
You need to pinpoint where the noise is coming from, if in the area of the master cylinder, then I would check the motor.
2004 Limited V8
