View Single Post
Old 12-14-2020, 02:28 PM
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
There is actually not a lot of clearance between the tire and the mud flap on the front, even with stock-sized tires when the wheels are turned. If you remove the front mudflap and carefully check clearance, you should be OK. Toyota is stating this mainly due to the exact reasons you mentioned - not all tires are of equal actual size, even if they are listed as the same size on the sidewall.
ahtoxa11 is offline   Reply With QuoteReply With Quote
