Don't hammer on the starter or solenoid, tap maybe, but it maybe better to cross the positive large terminals with screw driver to start but NeVeR hammer/tap on a starter or solenoid if you want to rebuild the OEM parts, any other starter will be sub-par components compared to the Toyota starter you wanna keep, it's just the copper contacts in the solenoid that wear down over time you can easily replaced for $30.
