SWAY AWAY has good stuff. Back in the day they had rust issues, not sure if AFE fixed that.
Originally Posted by fkheath
Why do you need a new "rear suspension"? Springs don't go bad (in the old days they would sag, but not on modern cars). The only reason to replace the springs would be to have a different spring rate or load carrying capacity.
If your shocks are bad, just replace those which would cost a lot less than replacing the springs.
because stock sucks
