Originally Posted by 2K24RNR
I just ran out and checked.
When the driver door is locked the first turn of the key unlocks that door only as you said. The next turn does not unblock the other doors. I do hear the same mechanical sound from the driver door but no other sound from other doors.
Only the driver door unlocks automatically if I try to lock the rig with the keys in the ignition.
I am able to lock and unlock both front doors with the key in the front passenger door. However, the interior passenger door lock switch locks and unlocks only the driver door.
Thanks
Sure is sounding like the lock wire is not making contact outside the drivers door. This is why I was suspecting busted wires in the driver door jam. As they are only working mechanically. As they seem dead outside your door.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
