Maybe try a dremel with a plastic wheel brush or a soft fine brass wire wheel, you will go through the plastic brush wheels quickly, so you might want to have a few on hand, this won't cause damage to the sealing surface, maybe someone siliconed them in last time or you have a lot of sludge built up, I don't recall mine being that hard to clean up and I don't bend the retaining lip that holds the seal it will tuck under that lip then press in place.
