Originally Posted by T4topher
Could try a big crescent wrench with a really long cheater bar (must be willing to sacrifice your wrench for this). With enough leverage it should bend although that is some pretty thick metal.. worth a shot..
This, 100%. Used to do stuff like this at a welding shop I worked at all the time. With a long cheater bar you can do it cold. Cold will damage your finish less, and won't mess with the hardness of the steel.
If you have a pipe, but no big crescent wrench, cut a 1/4" wide slot in the pipe and try that.
