2004 Limited Air Flow Control stuck
Hi, my 2004 Limited circulation control has stopped working, will only blow straight out no matter what circulation button you push. Defroster, floor, etc all light up but air flow is unchanged, always straight out at you. Had the compressor replaced a couple of years ago, everything is cold or hot depending on air temp setting but flow switch has me confused on what it could be.
Thoughts? Thanks
