View Single Post
Old 12-28-2020, 03:14 PM
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Try recalibrating it, even non-lifted it will need to be recalibrated over time due to wear and sag. Not sure if this is the correct method, maybe search T4R to compare calibration methods for clarification. If you read further into the thread there was a 2nd process some needed to perform for deceleration aswell as the yaw calibration, but sounds like a yaw issue.
01-02 4Runner How to Zero Point Calibrate your VSC system. - YotaTech Forums
Malcolm99 is offline   Reply With QuoteReply With Quote
