Originally Posted by Charlievee
Where did you tap into the 12v illumination for the switch?
See the enclosed wiring diagram above.
Connect wires to the Wiper warmer switch:
Gray - dimming ground
Green - 12V illum power
I just used a regular chassis ground, so my switch backlight does not dim.
Note that these wires are very small gauge. I used an exacto razor blade knife to carefully slice off some insulation to expose the wire and soldered to it. Be sure to insulated and strain relieve with tape or cable ties so you don’t tug on them too much after installation.
