Real Name: Elliott
Real Name: Elliott
Originally Posted by riceandpho
fit the biggest, 31 fits, 27f fits.
i run dual group 31 though with what i have.
some of the group 31 might have the negative post too high and itll hit the hood. some reason the northstar battery i have is like that, took that post off and used a bolt and change the wires with ring terminals, i have alot of those and used a hydraulic crimp. the other brand odyssey battery was a better fit, the negative post is just right.
Do you have the pair side by side in the oem location or did you have to mount the second elsewhere? I'm looking into getting a pair of 31s under the hood
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
