Real Name: Elliott
Real Name: Elliott
Originally Posted by hinmo24t
@ 81runner
those diodes arent available on amazon anymore. im seeing people talking about soldering them as well? directional. before i go to shop to changeout battery or after, etc...
with my truck being a pretty basic model 2004, im guessing i dont have the bigger alternator for the AGM requirements. its a pia to actually view the label on stock alternator. not sure how to test it.
lol...might get a regular battery for $80 MaxxStart walmart and call it a day at this point.
reminds me of 'easy' tasks at work. careful what you wish for. hybrid bumper/winch = way more than that. light, wiring kit for light, battery, diodes, alternators, battery fitment, and im sure a few other surprised along the way
You can just look up a 1N4004 diode, they typically come in a ribbon of 5 or more. Cathode goes towards the firewall, it's the side of the diode with the stripe on it. I DID NOT solder, I folded the leads over and inserted them directly into the fuse buss with a small screwdriver. If there's an issue, the diode will pop like a fuse.
Lead acid batteries can handle up to 14.8v, so this mod won't hurt the vehicle with the existing battery.
The only issue with the alternator is in the AMPS it's capable of producing versus the load you plan to run, and you aren't running anything big so no issue. The voltage regulator comes preset for some reason to 13.2v. hence the diode. In older cars, it was totally normal to have an alternator pumping 14.4-14.8 all day long. AGM likes at least 13.6 to be happy.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
