Originally Posted by 702tripgen
Curious as to why FJ springs are being used in the front of 4th gen Runners especially with V-8's and 5100's. The 5100's will allow you to raise ride height, and the FJ are all V-6's so wouldn't those springs have less load rating than the factory 4Runner V-8 Springs?
Are the rear FJ springs load rated higher or just generally longer than stock 4runner springs? Thanks
From my understanding the FJ springs have a higher spring rating. I did the 5100/FJ swap (leaving the perch on the bottom setting) and netted exactly 1" of lift with my v6. I plan on moving the perch up one spot to the .85" setting in the near future however.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
