Originally Posted by delloro
You cannot prove that. It may well be true, but Toyota has not said so. So it is your opinion.
Well then what happened? Tourette's syndrome? Computer possessed? Were you hacked by the anti-0w-20-Industrial-Complex? Somebody have a gun to your head?
I'm thinking you dragged this thread off-topic because you really did 'want to get into it here.' ��
This is a thread about oil leaks, not your personal choice to disregard your owner's manual and your apparent desire for company in doing so.
See the thread in what you quoted.
Page 465 in the owners manual.
"SAE 0W-20 is the best choice for good fuel economy and good starting in cold weather. If SAE 0W-20 is not available,SAE 5W-20 oil may be used.However, it must be replaced with SAE 0W-20 at the next oil change"
Except Puerto Rico.
https://www.toyota.com/t3Portal/docu...f/OM35B46U.pdf
Why is that? What do they use there? 0W8?
What if we don't live where it gets cold?
Say like in the UAE where they recommend 5W30 through 15W40 for the SAME engine.
Page 832/833
https://nd-auto-styles-temp-producti...0_bookmark.pdf
Replicate via this link
Owners Manual
And I suggested to the user to use a thicker oil which MAY help slow the leak, and depending on the base, may help slow it even more.
She doesn't seem to have the cash or know-how to DIY.
After all, we are not all swimming in pools of money, so I made the easiest, most obvious suggestion for her to try and see if it slows.
Here is one from Australia. Page 338 and scroll up 1 page to see the info is for the 1GR.
https://toyotamanuals.com.au/docs/fj...ug-14-current/
