View Single Post
Old 12-31-2020, 11:20 PM
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
From what I have seen OEM should be good for 200k change intervals on a stock rig used for highway and dirt roads(not mudding or water crossing), if lifted over 2" you're on your own and might wanna do it every 60k, the range of a stock LBJ doesn't allow much droop lifted beyond 2-2.5" and will cause excessive wear and even binding and separation due to the design. I wish these OEM LBJ would go down in price!!, but I guess we should be glad there available.
Malcolm99 is offline   Reply With QuoteReply With Quote
