View Single Post
Old 01-02-2021, 03:02 PM
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
You don't hear of runout on the rear axle shafts to often, but maybe it's because few of us check for axle shaft runout. Instead of putting it on a lathe to check it you can roll the axle shaft on a perfectly flat table and look for a wobble. I got rid of my whom whom with a new rear driveshaft, but might pull my axles and check for good luck, thanks for the update. Was it the p-side or d-side axle, I would think the p-side gets more abuse.
Malcolm99 is offline   Reply With QuoteReply With Quote
