Originally Posted by Bad Luck
Where did you get the toyota key wafers from?
Toyota TR47 Pinning Kit (A-30-108)
– CLK SUPPLIES, LLC
just to be 100% clear. I purchased a new ignition cylinder. Then I did all the other cylinders in the truck to match it. if your going to re-do your own ignition cylinder you will have to drill a hole in it. not a huge deal and it's not hard to do it and I had 2x old ones I had saved so I could mess with it... vids on youtube show how it's done.
having a new ignition cylinder and fresh cut key is so... smooth like butter...
also keep in mind... have a couple of sets of cylinders for each one... my back one was broken on the inside and the little spring door would not function correctly after disassembly. a spare saved the day for me and I ended up swapping bodies with it.
it's very tedious stuff. but worth it in the end.
